550
How can I clean off tacky flux?
I've been using tacky flux to solder small pin-pitch packages with a flat tip, and it's been awesome. But it is quite a terrible time when it comes to cleaning. I've tried 70% isopropyl al...
solder
tacky-flux
Jul 01,2021
Ed Ouellette
