467
[PCB Design]
How to cancel the AD pad simplification process?
PCB
AD
Solder-pads
asked
Sep 29,2022
1639
How to add through solder pads of different shapes in Eagle Board?
I searched everywhere and watched many eagle tutorials, but I couldn't find out how to place circle and square through hole solder pads.In the Eagle parts list, I only found the octagon solder pad...
pcb-design
solder-pads
Eagle
Sep 09,2021
PCBWay happy
