511
Prepare panel of small board
Hello,I want to send you my design. My board is 30mmx40mm. I would like to order a panel. What is the standard suggested panel size where i can utilize the space.Thank youDimitar
panel
small-size
Dec 08,2019
SAYANTAN ElectroPoint4u
Piezo PCB motor refrence design.
Payment by wechat
PCB Stiffeners material specs
variable state filter pcb
