415
How do I wire the led to a power source
Hello, I bought led strip that I plan to connect to a power bank. The strip is rated at 5v and has 144 WS2812B leds. The both sides of the strip have 3 pin connectors and 2 wires for ground and power....
power-source
led
Aug 17,2020
Paul H
