5
429
My PCB needs a transformer, how do i find a supplier for to include in the BOM ?
Hi,I'm working on a PCB that will be powred throuth a 220VAC, i'm stepping down the 220v to 12v then to 5v throuth a step down transformer and a voltage regulator.the 5v needed to power the mi...
bom
pcb-assebly
Feb 17,2020
