427
flex pcb metal finsih
Hi,We are interested in the options for flex PCB metal finish.Using the ENIG or Hard Gold options:1) what is the thickness of gold that can be deposited? 2) Is it possible to achieve a 100um thickness...
metal-finish
flex
Dec 17,2019
variable state filter pcb
Jack Durie
