367
What size of resistor and capacitors did you use?
Hello! I ordered these printed circuit boards. can you tell me what size resistors and capacitors you used? https://www.pcbway.com/project/shareproject/15W_FM_RD15HVF1_AMPLIFIER.html
fm-amplifier
fm
rd15hvf1
Apr 18,2021
Bora Colak
