405
How to prevent DIP pin from connecting to Vcc layer.
I have a 4 layer board with internal power layers. I'm trying to add a decoupling cap to a DIP IC. The problem I 'believe' I have is that the 10 Pin is set to Vcc net and Altium is c...
pcb-design
Altium
decoupling-cap
Vcc-layer
DIP-pin
Sep 25,2020
Remy
I woul like to know how much it woul cost to realise and print a circuit board ot the picture included here. It is a two hour power failure alarm.
Components kept in stock by PCBWay for assembly
