537
[PCB Assembly]
Can anyone help? To ground the centre pad of the IC.
Hi,Can anyone help me out to rectify this error. I need to ground the centre pad of the IC, as tried of placing a via in the centre pad, and grounding it but I am facing this error. Thanks in advance.
pcb-design
ground
IC
centre-pad
Jun 22,2020
Joson
