3answers
[Others] MCU controlled buck converter?
If it's possible to control the power output of a 12V/150W heating element using some sort of buck converter circuit. It should step down the 12V input to various voltages required to vary the out...
3answers
[Others] Adding "Continuous current limiting" to a Buck converter with "Short Circuit Protection"
Hi, I have a beefy 12V 60A output buck converter which is advertised as having "Short Circuit Protection", I was wondering if I can use a current limiting circuit to essentially make this su...
2answers
[Others] Raspberry Pi Power Circuit Advice Needed
Looking for advice on improving this circuit. I use a 3S Li-Ion battery into a buck converter to power a Raspi trail camera with an on/off switch and led indicator.I use a largish resistor because I l...
  • answered Jul 31,2020
    by Gorge
1 PCBWay Team 6
