651
Brownout Detection error on LiPo powered ESP-32 PCB
Hi all,For a project I created a custom PCB.It's a LiPo powered PCB with ESP32-WROOM-32E module, Lipo charging module, 3.3V Voltage regulator and MPU6050 Acc/Gyro unit. Charging via USB-C connecto...
pcb-design
brownout-detection
HT7333-7
voltage-regulator
LiPo
ESP-32
Feb 08,2023
matt
