5
398
If it's ok multiple NPN 8050 transistors be used in parallel to increase the maximum amp draw?
All I have are a bunch of 8050s and I want to use them as power switches for driving a DC motor. Since the motor will draw more then the maximum amperage rating for an 8050 I was wondering if I could ...
base-pin
power-switches
NPN-8050
Jan 13,2021
Nikola Krneta
