476
Organising Custom Libraries.
When working with custom libraries, how do you arrange your directories? I'm tossing up between having a central "custom libraries" directory, that all future projects can pull from, or ...
arrange-directories
kicad
Custom-Libraries
Sep 10,2020
Remy
variable state filter pcb
Jack Durie
