1187
What a PCB Is Made Of
A basic PCB starts with a copper-clad fiberglass material or thin copper sheets adhered to either side of the board, as shown in Figure 1-5.Figure 1-5. Core material.With a multilayer board (a board...
Thru-Hole
Plated-Hole
Pad
Solder-Mask
Solder-Flow
Copper-Plating
Pre-Preg
Core
copper
PCB
Nov 23,2019
Babu
Jack Durie
