312
About mega drive fram 4mb pcb
Hi, really amazing pcb. I am looking for the same but compatible with Sega 32x cartridge shell, so only can put holes in different place. Is it possible that you can make one compatible with 32x and m...
Sega-mega-Drive-32x
asked
Jul 12,2023
albertuain
Piezo PCB motor refrence design.
Payment by wechat
PCB Stiffeners material specs
variable state filter pcb
