538
[PCB Design]
Esp32 + second radio module for Bluetooth
I need to have the ability to connect to both Wi-Fi and Bluetooth simultaneously. I wanted to use the ESP 32 and add a second radio module. My thought is the ESP 32 would handle the Wi-Fi ...
Simultaneous-use-of-Wi-Fi-and-Bluetooth-on-ESP-32
Second-radio-on-an-ESP-32
simultaneous-Bluetooth-and-Wi-Fi
Esp32
Apr 23,2023
lancelot
Piezo PCB motor refrence design.
Payment by wechat
PCB Stiffeners material specs
variable state filter pcb
