8
524
Draw PCB without schematic
I would order all kinds of PCB's if I had an easy way to draw them. I tried programs like kicad and a bunch of others but they are just far to complicated. So I am still stuck with perf boards.It ...
PCG-Design-Software
Mar 24,2023
