10
636
[PCB Assembly]
Which USB or components need PCB edge?
Please see the picture below. In the PCB file, the customer wrote a PCB EDGE with a line next to it, but it does not match the shape.The customer replied that the line and characters can be deleted, b...
USB
PCB-edge
Dec 22,2021
Sayanik Mandal
