786
[PCB Design]
What inspections are needed after PCB design?
In the manufacturing industry, after the process designer has designed the PCB, does it need to check the design results? The answer is yes, and there is more than one way to check.The first is DRC in...
DRC
DFM
PCB-design-inspection
Dec 22,2021
Wade Kindberg
