313
Are there licensing issues if I share a design that uses an HDMI ?
If I upload a design that uses pure DVI protocol (no audio, no HDCP, no logo) over an HDMI connector, are there licensing issues if I share that design with the community? I read that there are ...
HDMI-DVI-licensing
Mar 12,2021
Nikola Krneta
