708
4 layer Flex Rigid design with eagle
Hi,I'm looking for build a 4 layers flex rigid pcb,at one end the Rigid part and on the other end the flex part with components.To do this i understand thal i should seperate the rigid from the fl...
eagle
Flex-Rigid
Feb 20,2022
shamir.br
