598
[PCB Assembly]
Lead time for DIY Solar Lamp PCB
Hi, thank you for making this project available. If I order the PCB, what would the lead-time be (PCB details below)?Thank you for your time RegardsMark.PCB:DIY SOLAR LAMP2 Layers PCB 5 x 5 ...
Lead-time
DIY-Solar-Lamp
Oct 16,2019
