489
[PCB Assembly]
Can you create this
Can you find me a circuit board that has 1 power terminal, 4 motor terminals, and a remotely controlled navigation system (up down left and right). Please give me multiple options.Thanks.
Circuit-board-shopping
Feb 28,2022
Manoj kumar
