Hello,
I am relatively new to this, and still just trying to get my bearings with these programs. My goal is to mill relatively simple circuit boards on a protomat, starting with a Fusion 360 design. However, I want to start from a simple 3D design in Fusion 360, as opposed to the 2D/3D PCB builder (as shown below). This is an ultra simple example, but in general, the circuitboards will be simple enough to continue this strategy, using the dimensions of my laminate to ensure a 50 ohm impedance.
When I attempted to import this as a .dxf file into CircuitCam, I couldn't. I'm assuming this has something to do with the inability to define layers, but is there a workaround/solution using these design types in Fusion 360, or must I use the PCB builder?
1 | PCBWay Team | 6 |
