In KiCad, How should I designate the flex areas of a rigid-flex board?
rigid-flex
rigid
flex
kicad
James Patrick
asked Aug 08,2021
I have a rigid-flex design which consists of two rigid sections connected by one flex section. How do I convey to the fabricator which areas I want rigid and which areas I want flex?
rigid-flex
rigid
flex
STK-0050II
Do you sell SPI finish cards?
Copper washer
Threaded inserts specifications.
Other RF materials besides Rogers
SHipping cost to usa
Any el84 se/pp project.
Procedure for have a board from a github repo made
Silicone mold
I need to design a PCB for a custom gamepad that is compatible with PS5. Which IC should I use for this?
account closure
merhaba kullanılan malzeme listesini paylaşır mısınız
What is the cheapest way of jamming a wifi connection?
SPI surface finish sample card
Custom Ink colors
Delivery to Yemen is available?
PCB Flex heaters
What can I expect regarding lead times on assembly
Small PCB with open cavity
SMD assembly and stock
Mason Goebel
