Bend cycles of flex and rigid-flex pcbs
datasheet
ordering
question
bend
bending
rigid-flex
flex
T B
asked Apr 13,2023
Hello, how many bend cycles can the flex and rigid-flex pcbs handle?
datasheet
ordering
question
